Reply To: Possible to use data from external text file as parameters?
Home Forums Problems and solutions in GDL GDL add-ons Possible to use data from external text file as parameters? Reply To: Possible to use data from external text file as parameters?
#4004
the example is just a small modification of your code:
DIM sarray[]
var = ""
filename = "ProjectNotes.txt"
ch1 = OPEN ("text", filename, "MODE=RO, LIBRARY")
j = 1
sarray[j]=""
repeat
	n = INPUT (ch1, j, 1, var)
	pos = STRSTR (var, "EF-25")
	sarray[j] = var
	j = j + 1
until pos = 1
CLOSE ch1
VALUES "refnote" sarray
I haven’t tested it, I guess it should work 🙂
The easiest way to debug GDL when you don’t know what is happening is to use PRINT commands. Or, you can use BREAKPOINT with the debugger, as explained here.
