Reply To: Dangers of using GLOB_​​​FEEDBACK_​​​MODE in Parameter Script
Home Forums Problems and solutions in GDL Parameter connections Dangers of using GLOB_​FEEDBACK_​MODE in Parameter Script Reply To: Dangers of using GLOB_​​FEEDBACK_​​MODE in Parameter Script
#4105
GLOB_FEEDBACK_MODE is view dependent, so it shouldn’t be used in the parameter script – this includes the master script when it runs as the parameter script (which it will do).
You would probably be better off using it just in the 2D and/or 3D scripts.
