Home › Forums › General discussions › Using updated parameters in properties script › Reply To: Using updated parameters in properties script
August 7, 2018 at 02:10
#4208
David Shorter
Hi Matt
Not sure what you are actually trying to do. What sort of object are you trying to create?
Probably it would be easier to create a property and achieve totals when you SCHEDULE.
Usually the ‘update’ occurs when you schedule.
Provide a bit more info and we will try and help
