Reply To: AC22 new Label fixed parameters
#4262
Geoff Briggs
More on the inconsistent application of “Use Text Pen as Uniform Pen”. I have another label where the override does work on POLY2_Bs. I tried swithchng my first label from POLY2 to POLY2_B but that did not fix it. So I have no idea when it is applied, just that you cannot trust it.
Also I see that “Use Text Pen as Uniform Pen” does not override the built in pointer line or arrow. I seems like it should. That’s what “uniform” means after all.
If this feature cannot be made to work it should be removed.
Geoff Briggs
DeForest Architects
Seattle, USA
