Reply To: Write text file to embedded library
Home Forums Problems and solutions in GDL GDL add-ons Write text file to embedded library Reply To: Write text file to embedded library
#4295
Yes, it can. You have to add the “data.txt” (or other filename that you are using) to the embedded library first.
Another limitation is that in teamwork the user needs to reserve the file to be able to write to it.
