Home › Forums › Problems and solutions in GDL › GDL add-ons › Write text file to embedded library › Reply To: Write text file to embedded library
November 7, 2018 at 16:05
#4317
James Goode
There are several. This issue is that it definitely works.
Nonexistent channel
at line 68 in the 2D script of file Survey Point Output.gsm.
Nonexistent channel
at line 69 in the 2D script of file Survey Point Output.gsm.
Nonexistent channel
at line 70 in the 2D script of file Survey Point Output.gsm.
Nonexistent channel
at line 71 in the 2D script of file Survey Point Output.gsm.
Cannot modify the file (filelog.TXT) in embedded library in 2D script type.
Open error
while operating on file 'filelog.TXT'.
Nonexistent channel
Nonexistent channel
Nonexistent channel
Nonexistent channel
Open error
Open error
Open error
Open error
Open error
Open error
