Home › Forums › Problems and solutions in GDL › 3D modelling › LIBRARYGLOBAL – MESS UP › Reply To: LIBRARYGLOBAL – MESS UP
March 4, 2019 at 13:27
#4571
1. LIBRARYGLOBAL should be used in 2D and 3D scripts. If you put it to the master script, you should limit the usage with a condition using GLOB_SCRIPT_TYPE.
2. If you are reading the proper paramvalues of the MVO object in 2d and 3d scripts with LIBRARYGLOBAL, you’ll always get the values for the current view. Do not need to force anything…
