Home › Forums › Problems and solutions in GDL › Documentation elements, text handling › Issue with label and surface override › Reply To: Issue with label and surface override
March 12, 2019 at 13:29
#4602
Hi David,
The dialog is correct, this is how AC works. Greyed settings don’t reflect the current state of the object, they show what will happen when the override is enabled. For example complex profile walls can have more than three different surfaces, composite wall edges can have more than one surface.
New walls will get the tool default settings, including surface overrides. Could you describe the workflow to get the “ghost” that is not correct?
