Home › Forums › Problems and solutions in GDL › Informations from the environment › AC_Sill_To_Curr_Story: Bug or Not? › Reply To: AC_Sill_To_Curr_Story: Bug or Not?
May 30, 2019 at 08:48
#4764
There is a workaround until it is fixed:
A property can be set up to be based on an expression. For this expression you can select parameters that are the same as in IES. You can display the evaluated
expression with Classification and Properties Label.
