Home › Forums › Problems and solutions in GDL › Others › Variable Mismatch › Reply To: Variable Mismatch
June 25, 2019 at 06:58
#4797
I would say …
IF isFirstRun THEN
execute code....
ENDIF
At least this is what has been mentioned in other posts about it.
I think it may be a little confusing and ‘isfirstrun’ only gets a value when it is the first run.
I am not sure if it gets a higher value on multiple parameter script runs.
I still don’t understand your code.
ProHeight = abs(_yMax - _yMin)
SquareV2 = ProHeight / ( cos(phi) )
SquareV2 still has nothing to do with the first bit of code you posted.
