Again, Global parameters
This topic contains 1 reply, has 2 voices, and was last updated by  Gergely Fehér 2 years, 3 months ago.
  • #3809
    Frank Studzinski
    On of our large clients use a customized zone stamp for several years.
    In this they uses many calculations with GLOB_HSTORY_ELEV, GLOB_HSTORY_HEIGHT.
    F.e.
    UKRD = GLOB_HSTORY_ELEV + ROOM_HEIGHT
    PARAMETERS UKRD = UKRD
    LOCK “UKRD”
    Since AC18 it works fine for them, but with 20 it didn’t work.
    They use the result for the UI and for schedules.
    What could be a workaround?
    They also ask why these values are not supported in Parameter Script?
    Graphisoft Berlin GmbH
  • #3810
    GLOB_HSTORY_ELEV is a project dependent global variable, so it is not allowed to use it in parameter script. In gdl elements there is no workaround for it.
