Angle editing hotspot locks at '0' in 3D
Home Forums Problems and solutions in GDL Graphical editing Angle editing hotspot locks at '0' in 3D
This topic contains 2 replies, has 3 voices, and was last updated by  Bruce Walker 1 year, 2 months ago.
  • #2411
    Kristian Bursell
    Whenever I use angle editing hotspots (4, 5, 6, 7 – never actually used 7) in 3D there is always an issue when the values is zero (0); I cant move it. So i go into the settings and change the value manually (grunt, sigh) then it is free again to moved as expected but as soon as i move it back to zero it locks in that position again.
    Is there a trick to avoid this?
    it works fine in 2D.
    CADSWIFT
    Australia
  • #2413
    Maybe you do need to use ‘7’.
    Here is the code I use to change the pitch on my barge object.
    No problem stretching it to or from zero.
    		r = 0.350
    		HSID = HSID +1
    		hotspot 0, 0, 0, HSID, Ptch_Inp, 6			!center of angle
    		HSID = HSID +1
    		hotspot r, 0, 0, HSID, Ptch_Inp, 4+128			!base hotspot
    		HSID = HSID +1
    		hotspot r * cos (Ptch_Inp), 0, r * sin (Ptch_Inp), HSID, Ptch_Inp, 5		!moving
    		HSID = HSID +1
    		hotspot 0, -1, 0, HSID, Ptch_Inp, 7			!center of angle
    		HSID = HSID +1
  • #3977
    Bruce Walker
    I don’t know if Barry’s answer solved the problem, but the ‘7’ defines the rotation axis. Without it, I guess ARCHICAD doesn’t know which way the axis goes if the angle is 0.
    www.brucepwalker.com
    NVIDIA GeForce GTX 1060 8Mb
