Are there parameters for Monolith Stair Structure's surface/bmat?
Home Forums Problems and solutions in GDL Documentation elements, text handling Are there parameters for Monolith Stair Structure's surface/bmat?
    • #18668
      Palawat Dhammamitr
      I’m improving my label to be able to read stair structure’s surface and building material.
      For other types (Beam, Cantilevered and Stringers Only), I can request info from associated library part without any problem. But I can’t do that with the Monolith type. And I can’t find anything regarding that in the GDL ref guide.
      Are there parameters I can use to get the Building Material and Override Surfaces from Monolith structure (both flight and landing)?
    • #18669
      No, monolith structure isn’t a library part, so you don’t have information about it’s parameters in a label.
      It’s properties are accessible, try the “Classification and Properties Label” for a demonstration.
      It is possible to define a property whose value is an expression, and this expression can be the building material of the object. Though currently stair structure surfaces aren’t available in a property expression.
    • #18670
      Palawat Dhammamitr
      I see. Thank you very much, Péter.
  • The forum ‘Documentation elements, text handling’ is closed to new topics and replies.
