Array Parameter Lock Issue
Home Forums Problems and solutions in GDL Parameter connections Array Parameter Lock Issue
This topic contains 3 replies, has 3 voices, and was last updated by  Gergely Fehér 3 years, 7 months ago.
  • #2877
    Dami Soh
    Hello,
    We’ve run into a problem in ARCHICAD 20 with the Array parameter.
    I have posted this issue on Test Track, but was referred to the GDL Help site for answers. (The case number is 60237 for your reference)
    I’ve attached a detailed account of the problem that we are running into in the word doc below. Also attached is the sample GSM file of the issue.
    We’re not sure if this is a bug or if there has been a change in GDL scripting structure for AC 20 (this could be problematic when we upgrade previous versions of GDL libraries and add-ons).
    Please get back to us soon!
  • #2879
    I can confirm this and other strange things are happening in the script editor for 20.
    If I copy and paste in the main script window it appears correct but it is not really working.
    Look in the pop-out window and it is not there or something completely different happens which destroys the script.
    It may look Ok but it isn’t.
    Look at this simple example where I have copied and pasted a small piece of script.
  • #2881
    Dami Soh
    Looks like the sample GSM file didn’t get posted.
    Below is a link to download the sample GSM file and a video recording of the error from Google Drive:
    https://drive.google.com/drive/folders/0B8Nn5evyohOaNHV1cDZFTGM1UG8?usp=sharing
    Thanks!
  • #2883
    Thanks for the report, I’ll add this issue to our bug database, and we will check the possibilities.
