ASSOCLP_​​PARVALUE_​​WITH_​​DESCRIPTION
Home Forums Problems and solutions in GDL Informations from the environment ASSOCLP_​PARVALUE_​WITH_​DESCRIPTION
Viewing 8 reply threads
    • #3934
      I assume this is the version of ASSOCLP_PARVALUE to use with parameters that have a VALUES{2} list. If so, I don’t understand how to get the description part of a given value.
    • #3935
      I tried wtih the following code in a labels’ 2d script:
      dim p_values_and_descriptions[][]
      n = REQUEST ("ASSOCLP_PARVALUE_WITH_DESCRIPTION", "myParam", name_or_index, type, flags, dim1, dim2, p_values_and_descriptions)
      for ii = 1 to vardim1(p_values_and_descriptions)
      	for jj = 1 to vardim2(p_values_and_descriptions)
      		text2 jj, ii, p_values_and_descriptions[ii][jj]
      	next jj
      next ii
      This code writes both the integer value and the description to the floorplan view.
    • #3936
      Thanks, Gergely, but I’m not getting it. I did notice the TEXT2 line needs to be text2 j, i, p_values_and_descriptions[i][j]. But the label is still empty when applied. I’ve attached a simple test case.
    • #3938
      Again what I post does not show up. I was trying to say the text2 line needs to refer to p_values_and_descriptions[i][j], not just [j]. (Incidentally, I tried to bold the [i].)
    • #3939
      One more try. open square bracket i close square bracket open square bracket j close square bracket. Maybe it did the same thing to your text. Thanks again for the help.
    • #3940
      Sorry, I changed to ii and jj, I hope it helps. (The forum engine stoles the single i char in square brackets, as it thinks is is an italic definition for text formatting.)
    • #3941
      Thanks, I’m getting closer. The array dump works. How do I capture just the description? I get an error if I try to set a variable equal to p_values_and_descriptions[1][1], for example.
    • #3966
      Anything more on this?
    • #3996
      Gergely, I’ve submitted this as #244744. I would have PM’d you but I didn’t see the option.
  • The forum ‘Informations from the environment’ is closed to new topics and replies.
