Back referenced layouts
    • #18685
      The autotext format for listing the back referenced layouts seems to only list all of them as one string. Is there a way to get individual layout IDs out of the AC_BackReferenceGUIDList array?
    • #18692
      Anything on this?
    • #18695
      It turns out it wasn’t designed to be used by library parts.
      When AC_BackReferenceGUIDList[1] is used in a special autotext – “guid” where separator is a string and guid is AC_BackReferenceGUIDList[1] referring to the drawing title – then it is replaced with the autotext equivalent of the guids in AC_BackReferenceGUIDList[2-…] adding the separator between them.
      That is the only possible use of it, single GUID’s can’t be written as autotext.
      The user can select the referenced drawings after clicking Back Reference button in the drawing settings dialog on the Title tab. Theoretically you could filter AC_BackReferenceGUIDList in the parameter script, but that would interfere with this dialog.
  • The forum ‘Informations from the environment’ is closed to new topics and replies.
