Boolean array
Home Forums Problems and solutions in GDL Others Boolean array
    • #4479
      James Goode
      Hello,
      I have an object which I can add nodes via hotspots. I would like to be able to have a tick box for each possible node (turn on / off showing dimension). Is this possible to achieve? Thanks
    • #4480
      Hello,
      no, it can’t be done with GDL. You could show an array in the settings dialog, but that’s not intuitive for the user, not easy to match with the geometry.
    • #4664
      Bruce Walker
      The workaround is to switch on/off based on the hotspot’s position. I have used this on a traffic road arrow, where the position of the hotspot determines the type of arrow.
      www.brucepwalker.com
      NVIDIA GeForce GTX 1060 8Mb
