Checking library for file names
Home Forums Problems and solutions in GDL Informations from the environment Checking library for file names
This topic contains 2 replies, has 2 voices, and was last updated by  Péter Baksa 1 year, 4 months ago.
  • #4530
    shaun coomber
    hi
    Is there any way to check if specified file names are loaded into the current library?
    I’m importing values from optional txt files, and if the txt files aren’t loaded the report ends up full of these errors:
    File not found in the library
    while operating on file ‘#######.txt’.
    This is what I’m using:
    currentChannel = OPEN (“TEXT”, currentFileName, “LIBRARY, MODE = RO”)
    IF currentChannel = 1 THEN
    GOSUB “Import Text File Content”
    ENDIF
    CLOSE currentChannel
  • #4531
    shaun coomber
    For example, is it possible to use n = APPLICATION_QUERY (“LIBRARY_MANAGER”, “”, files_list) for txt files, or only IES and image files?
  • #4542
    Hi Shaun,
    no currently it’s not possible.
