coding for material takeoffs
Home Forums General discussions coding for material takeoffs
This topic contains 4 replies, has 2 voices, and was last updated by  Yafim Simanovsky 2 years, 8 months ago.
  • #3568
    Yafim Simanovsky
    Hello,
    I am not sure if GDL is strictly for 2D/3D component creation.
    I am trying to figure out the best way to write code for material takeoff in order to automate some processes.
    Is it possible to write code for this purpose, similar to Macros in simpler programs like excel?
    Which programming language is the best fit?
    Thank you
  • #3573
    You can create listis with the “old” listing feature of ARCHICAD. You can calculate nearly anything for that with the property scripts: http://gdl.graphisoft.com/reference-guide/the-properties-script
  • #3574
    Yafim Simanovsky
    Hi Gergely,
    Thanks for the reply.
    I think what you send can be applied to extract properties from specific instances.
    My question is more about how to for example extract a specific material takeoff of the entire model, let’s say to automate the process of “take all walls, extract their height length and U-value, put it in a table”.
    What do you think?
  • #3604
    I think that’s not a GDL related problem… GDL elements can not “take all walls”… At least you need an addon for that, you can start here: http://archicadapi.graphisoft.com/
  • #3606
    Yafim Simanovsky
    Thanks Gergely 🙂
    I am in the process of learning C++ now so that I can build an add-on myself that will do exactly what I want in Archicad.
