Combine request results
This topic contains 1 reply, has 2 voices, and was last updated by  Denny Wong 1 year, 9 months ago.
  • #4202
    David Cook
    Hi
    I have a zone stamp that has the following line in the Master Script which returns the ID of the zone. Works great.
    x = REQUEST("ID_of_main", "", IDText)
    We’ve got a project where we want to hot link in a module several times and add the prefix. Now I can get the prefix to show up, but not the ID if I change this line to
    x = REQUEST("Full_ID_of_parent", "", IDText)
    Is there any way I can do a double request
    x = REQUEST("Full_ID_of_parent" & "ID_of_main", "", IDText)
    or filter the results into a secondary line of code to get the IDText variable to display them as a combined result?
    x = REQUEST("ID_of_main", "", IDTexta)
    x = REQUEST("Full_ID_of_parent", "", IDTextb)
    IDText = IDTextA & IDTextB
    Appreciate any assistance/advice/ that can be provided. I’m still relatively new with this side of the GDL commands.
    Regards
    Dave Cook
  • #4224
    Denny Wong
    Hi David,
    Not sure if I got your question correctly – this sounds more to do with string concatenation rather than the REQUEST itself. & operator in GDL is a Boolean operator; + is the operator you are looking for:
    n1 = REQUEST("ID_of_main", "", IDTextA)
    n2 = REQUEST("Full_ID_of_parent", "", IDTextB)
    if n1 and n2 then
      IDText = IDTextB + IDTextA
    else
      print "Something went wrong"
    I am not sure if REQUEST will give an Integer if IDTextA turns out to be all numbers, in which case you might need to do a VARTYPE then str(“%.0”, IDTextA) before concatenating.
    I also want to point out that if you put these REQUESTS in the Master Script, they will produce a numerical “0” if GLOB_SCRIPT_TYPE is Parameter Script. If you then try to + two 0s together obviously you will get a 0. If your confusion comes from seeing 0s as your script result, may be that’s the reason.
    kind regards,
    Denny
