Home › Forums › Problems and solutions in GDL › Lists and schedules › Components for walls from Wall_Zone_Border_Parameters
- This topic has 10 replies, 3 voices, and was last updated 5 years, 7 months ago by
Narendra Suryavanshi.
June 13, 2016 at 09:57 #2498
ParticipantHello,
I am trying to find components for walls from Wall_Zone_Border_Parameters. To begin I wrote following code.
!Wall-Zone Border parameters
A=REQ (“Gdl_WALLZ_LENGTH”) ! Wall-Zone border length
B=REQ(“Gdl_WALLZ_SURF”) ! Wall-Zone border surface area
C=REQ(“Gdl_WALLZ_DOORS_SURF”) ! Surface area of doors on Wall-Zone border
D=REQ(“Gdl_WALLZ_DOORS_WIDTH”) ! Sum of door widths on Wall-Zone border
E=REQ(“Gdl_WALLZ_WINDS_SURF”) !Surface area of windows on Wall-Zone border
F=REQ(“Gdl_WALLZ_WINDS_WIDTH”) ! Sum of window widths on Wall-Zone borderPRINT “WALL LENGTH”,Gdl_WALLZ_LENGTH,
“WALL SURFACE”,Gdl_WALLZ_SURF,
“DOOR SURFACE”,Gdl_WALLZ_DOORS_SURF,
“DOOR WIDTH”,Gdl_WALLZ_DOORS_WIDTH,
“WINDOWS SURFACE”,Gdl_WALLZ_WINDS_SURF,
“WINDOWS WIDTH”,Gdl_WALLZ_WINDS_WIDTH
When linked to zone through criteria The report window returns
WALL LENGTH 0 WALL SURFACE 0 DOOR SURFACE 0 DOOR WIDTH 0 WINDOWS SURFACE 0 WINDOWS WIDTH 0
instead of real values.Is the code wrong?
Is there any way to list zone related parameters?
Will someone help?Thanks in advance.
NS -
June 14, 2016 at 08:35 #2506
ParticipantHello,
I am stuck due to this issue. Will anyone help asap.
NS-
June 14, 2016 at 08:48 #2507
KeymasterThose requests does not exist in GDL. Zone stamps can reach many informations with fixed name parameters as it is listed here:
https://gdl.graphisoft.com/reference-guide/room-parameters/Gergely Fehér
June 17, 2016 at 07:41 #2522
ParticipantGergely Fehér
A thousand thanks for early reply.
I am aware of parameters in Zone stamps. But it becomes essential to write Property script inside the Zone.gsm to get components and resave zone.gsm. You have to repeat process at next upgrade / update form Graphisoft. Hence I was trying to write property script in a new property.gsm. Is there any way to write new script and call Zone.gsm parameters in it?Besides what are “Wall-Zone Border parameters” meant for?
Please reply.
Thanks once again.
NS -
July 7, 2016 at 13:41 #2605
KeymasterYou can create a property object, and link that property object to the zones. In the property object’s property script you can reach the zones parameters with “ASSOCLP_PARVALUE” request, and calculate anything based on that, and list with the old listing as components.
October 2, 2016 at 14:09 #2746
ParticipantSorry for a very delayed reply. I was ill.
I do not know how much trouble you can take for me, but I am an architect and not a programmer.
With “ASSOCLP_PARVALUE” I see a million possibilities, but some how I do not get success in writing proper code.
To start with I prepared request to get manufacturer’s name of window in property object and attached that to a Window library part. Code as below. The report returns all values as zero. Failed in spite of various alternates.
Kindly show what is wrong.
n=REQUEST (“ASSOCLP_PARVALUE”, “gs_list_manufacturer”, name_or_index, type, flags, dim1, dim2, p_values)
print name_or_index, type, flags, dim1, dim2, p_values
Thanks in advance.
Naraindrra-
October 4, 2016 at 10:47 #2748
KeymasterYour script should work: you have to enable “Interrupt with error messages” function in “Options/Work Environment/Model rebuild options” menu to let Print work.
Your script worked for me in a new label object (the print popup was visible in the settings dialog, and it printed to the report window as well). However, it’s better to inicialize your return variables to avoid GDL warnings (even the dummy ones, I did not do that now):
p_values= "" n = REQUEST ("ASSOCLP_PARVALUE", "gs_list_manufacturer", _dummy1, _dummy2, _dummy3, _dummy4, _dummy5, p_values) text2 0, 0, p_values
Use text2 command to output values instead of print, even if only debugging, to make sure.
Product Manager
October 4, 2016 at 13:25 #2749
ParticipantDominika Bobály,
Many thanks for the reply. However it simply doesn’t work in a property object. I copied your code.
Enclosing object file.
Please look into asap.
Regards,
Naraindrra -
October 5, 2016 at 07:02 #2750
It works.
Code
p_values= “”
n = REQUEST (“ASSOCLP_PARVALUE”, “gs_list_manufacturer”, _dummy1, _dummy2, _dummy3, _dummy4, _dummy5, p_values)!print p_values
!text2 0, 0, p_valuesDESCRIPTOR p_values ![, code, keycode]
Problem appears in Print / Text2 commands. Please find out why that happens and ask proper team to rectify.
Regards.
Naraindrra -
October 7, 2016 at 11:30 #2760
KeymasterHi Naraindrra,
Why do you want to use text2 or print in a property object? These object only used for listing, so I can’t imagine why they should use those commands.
October 10, 2016 at 07:25 #2763
ParticipantHi Gergely,
This is a question with very profound lead. I need some time to answer. I need to write few pages. I will certainly do that.
Simple answer to why I am using text2 or print in a property object is to test result at any line of my program. If there is any other way to do it kindly suggest.Regards,
Naraindrra
- The forum ‘Lists and schedules’ is closed to new topics and replies.
