Create graphical Hotspots from a marco called Object
Home Forums General discussions Create graphical Hotspots from a marco called Object
This topic contains 3 replies, has 2 voices, and was last updated by  Péter Baksa 1 year, 2 months ago.
  • #4584
    Samantha Mar Braga
    Which is the best way to get the graphical hotspots from a macro called object with several instance in a parent one?
    I tried that hotspotID and the angle rotation takes the value from a parameter an change in to a single “call” command, but it doesn’t work
  • #4585
    Hi Samantha,
    are you trying to make editable hotspots, or fixed ones?
  • #4589
    Samantha Mar Braga
    Hi Péter! Thanks for the quick answer!
    I’m trying to make the editable hotspots the magenta ones.
  • #4590
    If you need different rotations in each instance, you have to use a different parameter in each. The hotspot uses the parameter belonging to the parent object, not the macro.
    A solution for this could be that you pass an array of rotations, and an index telling which one to use from the array for the hotspot.
    An example with simpler length editing:
    parent:
    for i = 1 to 2
    	call "testmacro" parameters x = x, i = i
    	line2 0, 0, x[i], 0
    	add2 0, 0.1
    next i
    del 2
    macro:
    unID = (i - 1) * 3 + 1
    hotspot2 0,	0,	unID, x[i], 1 + 128	: unID = unID + 1
    hotspot2 x[i],	0,	unID, x[i], 2		: unID = unID + 1
    hotspot2 -1,	0,	unID, x[i], 3 		: unID = unID + 1
    parameters in both:
    x as length array
    i as integer
