Dangers of using GLOB_​​FEEDBACK_​​MODE in Parameter Script
Home Forums Problems and solutions in GDL Parameter connections Dangers of using GLOB_​FEEDBACK_​MODE in Parameter Script
This topic contains 4 replies, has 2 voices, and was last updated by  Barry Kelly 1 year, 11 months ago.
  • #4103
    Denny Wong
    Just want to get some clarity in what danger it is to use GLOB_FEEDBACK_MODE in Parameter Script.
    I am not hoping to store the value of the variable, (i.e. parameters something=GLOB_FEEDBACK_MODE) but rather its for holding back parameter checking until hotspot editing is done. (i.e. if GLOB_FEEDBACK_MODE then : !NO CHECKING : else : !PERFORM CHECKS : endif)
    Is there any danger or future compatibility issue with this?
    Many thanks in advance.
  • #4104
    Denny Wong
    Ok I learnt it the hard way how weird things can become when using GLOB_FEEDBACK_MODE in master script… I found a work around it anyway but it seems like there is some sort of caching of movable hotspots?? I am very confused…
  • #4105
    GLOB_FEEDBACK_MODE is view dependent, so it shouldn’t be used in the parameter script – this includes the master script when it runs as the parameter script (which it will do).
    You would probably be better off using it just in the 2D and/or 3D scripts.
  • #4106
    Denny Wong
    Thanks Barry, I fully understand that. However I am still quite confused over the fundamental principles of how the scripts interact when it comes to 3D Hotspot editing.
    What I am hoping to do is in simplest terms: make a hotspot a “drag button”, when triggered every time, it adds 1000mm to A. The button resets itself after each use.
    MASTER SCRIPT
    if flip_switch then
       A = A + 1
       flip_swtich = 0
    3D SCRIPT
    _unID = 1
    hotspot 	0,		0,		0,		_unID,	flip_switch,	1+128,	flip_switch: _unID=_unID+1
    hotspot 	-1,		0,		0,		_unID,	flip_switch,	3,	flip_switch: _unID=_unID+1
    hotspot 	flip_switch,	0,		0,		_unID,	flip_switch,	2,	flip_switch: _unID=_unID+1
    BLOCK A, B, ZZYZX
    PARAMETER SCRIPT
    values "flip_switch" 0,1
    if GLOB_MODPAR_NAME = "flip_switch" then
    	parameters flip_switch = flip_switch
    	parameters A=A
    However I found that the interaction between Parameter Script/3D Script/GLOB_MODPAR_NAME very weird during 3D Hotspot operations, GLOB_MODPAR_NAME is triggered continuously before the user finishes with the edit. The example above triggeres flip_switch 8 times every time you touch it, and it does not reset itself to 0 either.
    That’s why I am wondering if GLOB_FEEDBACK_MODE will be able to ensure that the editing is finished, THEN we reset the switch and change A.
    However what I found out the hard way is that even when the user finishes editing (i.e. during the last parameter script run before everything ends), GLOB_FEEDBACK_MODE is still TRUE even though at that point editing has ended.
    I probably could figure this out by some lengthy trials…
    NOTE This is AC19 I am testing on though.
  • #4107
    This is the best I can come up with at the moment – need to get back to real work!
    n = APPLICATION_QUERY ("parameter_script", "firstoccasion_in_progress", isFirstRun)
    if isFirstRun then
    	if flip_switch = 1 then
    		A = A + 1
    		PARAMETERS A = A
    !!		flip_switch = 0
    !!		PARAMETERS flip_switch = flip_switch
    This is what you need in the parameter script.
    Delete what you have in the master script.
    This works in 3D but you have to reset the hotspot to zero your self.
    Odd thing is the info box increases by 3000 but the object shows correct at 2000 (see image).
    If you open the settings dialogue it will increase another 1000 to 5000.
    Not sure what is going on there.
    If you in-comment the two lines in my script then it all works perfectly but the hotspot does not stretch any more as it is obviously being reset before the object adjusts.
    But changing the parameter in the settings dialogue works.
    This may give some help or maybe someone else has some better ideas.
