Home › Forums › Problems and solutions in GDL › Others › DEFINE TEXTURE does not work in AC 20
- This topic has 8 replies, 3 voices, and was last updated 5 years, 3 months ago by
Joachim Sühlo.
April 18, 2017 at 20:47 #3181
ParticipantI have the following problem:
DEFINE TEXTURE does not work in AC 20 with shadows as it works in AC 17:define texture “Texture1” “MW_Läufer_hellbraun”, 1.24, 1.24, 1 + 2 + 4, 0
define material “MW Ziegel, braun, NF” 20,
0.823529, 0.52549, 0.341176,
0.8, 0.8, 0.15, 0, 1, 0,
0.921569, 0.85098, 0.803922,
0, 0, 0,
0, ind(fill, “Misch-Schraffur 0%”), -1,
ind(texture, “Texture1”)material “MW Ziegel, braun, NF”
BLOCK 1, 1, 0.1
BLOCK 0.1, 0.1, 1If I use 514 or 512 instaed of 1 + 2 + 4 in the DEFINE TEXTURE statement, it receives shadows, otherwise not.
But 512 is a non documented value.
What must I do, that it works in all AC-versions?GDL Object Developer
MAC OSx 10.14 -
April 19, 2017 at 03:08 #3182
ParticipantI am not having any problem with your original code (I had to change the texture image and the fill in the material).
Can you post a screen shot of what you are seeing?
Are your sun/shadow settings the same in both versions?Barry.
April 19, 2017 at 05:12 #3184
KeymasterPlease never use undocumented bits… As they are not part of the “official” package, we can change them at any time, and then your objects will change.
April 19, 2017 at 08:45 #3185
ParticipantAttached yoe see a screenshot from AC 20 with both bits.
The Bits of 512 and 514 (512 + 2) are not documented, but they are auto created by ArchiCAD 17, if I use the Special Menu with save GDL as master.gdl.
MAC OSx 10.14 -
April 19, 2017 at 10:28 #3186
ParticipantI had no problem in 20 with your original mask of 7.
But I see from your image you are still in the GDL editor 3D preview.
I was looking at the actual Archicad 3D window.Maybe the shadows just don’t work in the GDL 3D window?
April 19, 2017 at 10:43 #3187
ParticipantHi Barry,
no, that was not the problem. In 3D main window the shadows are missing too.
And it seems not to be a platform problem, because on Windows for me
and my colleague (who works only on Windows) it is the same.GDL Object Developer
MAC OSx 10.14 -
April 20, 2017 at 10:11 #3194
ParticipantI am not sure what the problem could be – it is definitely working for me.
Other than the obvious that shadows are off in the 3D window settings or the sun is 0% in the 3D projection settings > more sun.
But I am sure that is not the case here.Just out of curiosity I thought I would try it again.
This time no shadow – see attached image.
Slabs and object next to each other.
It worked before but not now it seems.Attachments:
April 20, 2017 at 10:23 #3196
ParticipantHad a bit of a play and if you turn mask value 1 off (i.e. leave just 2+4) then all is good.
Likewise turn transparency off in 3D window settings all is good.
Seems like mask 1 is forcing the object to think it is transparent?Barry.
April 21, 2017 at 17:49 #3205
ParticipantThanks, Barry. This was in AC 19 the first time, where the Shadow is missing with mask 1.
MAC OSx 10.14
