dynamic arrays and returned_​​parameters
Home Forums Problems and solutions in GDL Parameter connections dynamic arrays and returned_​parameters
    • #2842
      Kristian Bursell
      Can we use the returned_parameters function on a dynamic array parameter in a macro? If so, how? I could not get it to work using the standard method.
      CADSWIFT
      Australia
    • #2845
      Dynamic arrays can be returned, but it will be converted to a single array. If we need to return data in this way, we usually return the sizes of the array first, the the array itself:
      end arraySize1, arraySize2, array
      After that in the caller object you can rebuild the original array in a nested loop.
    • #2846
      Kristian Bursell
      perfect! you guys are brilliant! all the answers follow the most direct logic and simplify very powerful functionality.
      CADSWIFT
      Australia
  • The forum ‘Parameter connections’ is closed to new topics and replies.
