File Manager, DIALOG
Home Forums Problems and solutions in GDL GDL add-ons File Manager, DIALOG
This topic contains 1 reply, has 2 voices, and was last updated by  Gergely Fehér 3 years, 7 months ago.
  • #2799
    Dávid Molnár
    I would play with some files selected by the user. If you use the DIALOG parameter, the user will be faced a dialog box to set the id string, which will be stored. But where? I need the selected path as a parameter or a variable. Is it possible?
    .-=<(molnkd)>=-.
    BIM-manager and object developer in Leipzig
    ArchiCAD 6.5-20 GER/INT, Win7/Win10
  • #2810
    It is stored in the addon’s internal database. It will be stored until ARCHICAD runs and the addon exists. If you restart ARCHICAD, the addon will ask again for the folder. It is not available in GDL scripts, so you can not store it in parameter in this case.
