Home › Forums › Problems and solutions in GDL › Library migration › Forward Migration
- This topic has 15 replies, 5 voices, and was last updated 7 years, 6 months ago by
Péter Baksa.
August 21, 2017 at 14:35 #3480
James Goode
ParticipantI am trying to be able to migrate one object and a lot of variations of that object from 19 to 21 using 2 different objects, one specific to 19 and one specific to 21. I can’t seem to get it to work at all. At the moment all I have is;
actualGuid = FROM_GUID
if actualGuid = “27D27CB8-5923-458A-80FA-6A8EC6B78CFF-CD32FA39-611C-47A7-A038-153F79AB5332” then
actualGuid = “27D27CB8-5923-458A-80FA-6A8EC6B78CFF}-{ABCDACD1-CE3F-CA4F-9195-B15EB1DAFA5F”
SETMIGRATIONGUID actualGuidAll it does it change the GUID of the original object (19) to the new object (21) but only if the actual GUID in the code above is exactly the same as the new object (21). I don’t know how to make this work.
Thanks
August 22, 2017 at 02:17 #3484
ParticipantAs far as I can see that should work – that is basically the script I use.
But as mentioned in Archicad-talk …However make sure you have the old GUID in the ‘Migration’ list – that is a different button to the ‘Forward Migration’ script. Do not have the new GUID in that list.
Also make sure you do not have the old object in you loaded libraries. If you do the swap will not happen.
August 22, 2017 at 07:50 #3489
KeymasterJames,
FROM_GUID always stores the main ID of your library parts – so “27D27CB8-5923-458A-80FA-6A8EC6B78CFF-CD32FA39-611C-47A7-A038-153F79AB5332” seems a bit too long, I think only the first half will be your old ID. The new main ID should be different – but in your sample it’s the same, so first change the main ID of yout object, then change the script to follow up this change from the old main ID to the new one.
August 22, 2017 at 08:02 #3490
ParticipantAs I look closer I also see your new ID has brackets in the middle – }-{
I didn’t notice the length of the ID (yes it is too long) but I think it is the last part that is the object ID.
Isn’t the first part the subtype?I always get my IDs from the MIGRATION list.
Press the ‘NEW’ button and then ‘Browse for Migrated Object’ to get the ID.
I also browse for the new object ID there but be sure to delete it after you copy and paste it.
Leave the old object IDs that you want to migrate in that list.Barry.
August 22, 2017 at 10:27 #3492
James Goode
ParticipantThanks very much, I had to pull the GUID from the Migration list as using the second half of the sub-type guid didn’t work. All working now. 🙂
April 30, 2019 at 15:16 #4712
ParticipantI have basic migration (replacement) working, but I can’t figure out how to get parameter values to transfer to new parameters. I have two simple objects, where the old one (AC21) uses the parameter ‘aSurf’ and the new one (AC22) uses the parameter ‘bSurf’. The new one doesn’t have the ‘aSurf’ parameter. Here’s the whole script:
!! Main guid of old placed version of object actualGUID = FROM_GUID _startID = '2BA958FF-7CD1-FF4F-BD14-865C49035B48' ! old version _endID = '4B5E33FD-B9DA-514D-AA20-7ECD437126D0' ! new version GOSUB 100 !! switch object SETMIGRATIONGUID actualGUID END ! +++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 100: IF actualGUID = _startID THEN rrr = STORED_PAR_VALUE ("aSurf", aSurf_val) ! get value from old bSurf = aSurf_val PARAMETERS bSurf = bSurf ! apply to new actualGUID = _endID ENDIF RETURNJames M
April 30, 2019 at 15:19 #4713
ParticipantSorry, I hit Submit too quickly. After migration, the placed new object in the migrated project has the default ‘bSurf’ value, not the different ‘aSurf’ value as the project was saved.
April 30, 2019 at 16:48 #4714
KeymasterHi,
If I understand right, you are placing a new element in the new AC version. Element defaults aren’t migrated this way, only placed elements. The settings dialog doesn’t store the parameters of the default object, just reads the actual default values from the library. Favorites I think should be migrated.
April 30, 2019 at 17:06 #4716
ParticipantI have a PLN from AC21 with a placed old object. When I open this in AC22 and load the new library, the placed object is migrated to become the new version. But I am trying to get the new parameter ‘bSurf’ to contain the value of the old parameter ‘aSurf’; instead bSurf has the value of the new object’s default. In other words, the value is not migrated.
May 1, 2019 at 02:32 #4718
ParticipantI use DELETED_PAR_VALUE – that works for me.
So …
IF actualGUID = _startID THEN rrr = DELETED_PAR_VALUE ("aSurf", aSurf_val) ! get value from old bSurf = aSurf_val PARAMETERS bSurf = bSurf ! apply to new actualGUID = _endID ENDIFBarry.
May 1, 2019 at 13:45 #4719
ParticipantOK, you need to turn AutoMigration off. What’s AutoMigration? Who knows, the manual is silent. Yes, I found the sole mention of it of AC-t, after I solved my own problem by chance. This Homebrew Computer Club stuff gets tiresome, tbh.
Thanks for the help, Barry and Peter.
May 2, 2019 at 07:13 #4720
ParticipantIt is all a bit of a mystery.
In the GDL manual STORED_PAR_VALUE and DELETED_PAR_VALUE seem to do exactly the same thing.
I figured I should use DELETED_PAR_VALUE if the parameter no longer exists in the new object, but I am guessing it doesn’t matter.I can find no reference as to what AutoMigration does, either here in the GDL Center or the Help Center.
Or if it is there it is just hard to find.I have always had AutoMigration turned off, so would never noticed it is a problem.
Also, I find it is easiest to use the ‘Migration’ section to find out the GUID of your new object.
You need the GUID of any old objects here – just don’t forget to delete the current object GUID once you have found out what it is and pasted to the migration script.
Otherwise the object will simply not migrate, and there will be no error messages to say why.Barry.
May 2, 2019 at 07:42 #4721
KeymasterLet’s quote that mention from AC-Talk here too, maybe it will be easier to find.
Automigration is a special type for migration: it simply does an ID change, without running migration scripts. It is useful to eliminate migrations from new elements, and create step-by-step migration logic through many versions.
_________________
GRAPHISOFT SEPéter Baksa
May 2, 2019 at 07:58 #4722
ParticipantAutomigration is a special type for migration: it simply does an ID change, without running migration scripts. It is useful to eliminate migrations from new elements, and create step-by-step migration logic through many versions.
So to clarify, if we just want to migrate objects with no parameter changes, we just add the old object GUID to the list and turn on AutoMigration.
It will ignore anything in the migration script.Here is the link to the actual post Peter has quoted from Greg.
I had forgotten I was even a part of that conversation. (insert embarrassed face emoji here).https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=58220&p=274105&hilit=automigration#p274105
Thanks Peter and Greg.
May 2, 2019 at 11:35 #4723
ParticipantWith Auto on, if the script is ignored, how does it know what new object to migrate the listed item to?
May 2, 2019 at 12:20 #4725
KeymasterThe migration is always run in the newer version of AC, on the new object. The old one doesn’t know anything about the new one. Old libpart GUIDs are listed in the migration table. When a library is loaded, all libparts’ migration tables are read and checked against placed objects.
Backward migration happens when saving as previous version .pln: the parameter list is saved with the GUID in the migration table listed at that version.
Some information about migration can be shown: in the Library Developer Menu select Log the Migration Process (then re-open the non-migrated file).Péter Baksa
- The forum ‘Library migration’ is closed to new topics and replies.
