Home › Forums › General discussions › GDL door and window parameters related to zones
- This topic has 3 replies, 2 voices, and was last updated 10 years, 7 months ago by
Gergely Fehér.
February 8, 2016 at 10:12 #2189
David Shorter44
ParticipantThere is a Door parameter in the door object “gs_list_location” which returns the name or number of a zone into which the door opens. Whilst the window object has a “location” parameter it does not link to the “gs_list_location” because there is no such parameter in the window object.
Unless I have missed something fundamental it would appear strange that a door can understand the relevant room but a window can’t.
Surely it is just as important for a window to understand the room (zone ) it belong to as a door. In some cases this is even more important.
Suggestions pleaseArchiCAD 4.1-22
MacBook RetinaDisplay
16Gb RAM 500Gb SSD
BIMXdocs -
February 8, 2016 at 22:56 #2193
KeymasterDavid,
As I know, windows in the AC19 INT library has this functionality too. Can you tell me which version did you try?
gs_list_location has nothing to do with the zones – it is just a parameter for listing, users can write anything to that parameter. You can read more about linking zones and openings here: https://gdl.graphisoft.com/tips-and-tricks/linking-openings-to-zone/Gergely Fehér
February 9, 2016 at 00:38 #2194
David Shorter44
ParticipantHi
19 INT
With the door this parameter can be automated using the “Location as” parameter.
You seem to have missed the point here. With the Door the user can automatically pull the name or number (using the “Location as” parameter) from the door to which it is attached. This is not possible with the window BUT it should be. I know the user can enter the value manually but this will only guarantee an error at some point. Automating the association of the window (and door) to its associated zone is an essential requirement. The keywords here are intelligent automation.
Hope this helpsArchiCAD 4.1-22
16Gb RAM 500Gb SSD
BIMXdocs -
February 9, 2016 at 15:23 #2202
KeymasterHi David,
As I tested it it seems the same to me – or I’m just testing some other parameters 🙂 Could you please send me a sample file with a door and a window between 2 zones and a schedule in mail to gdlcenter@graphisoft.com ? Please describe the problem in the file. Thanks in advance.Gergely Fehér
