GDL label for object info
Home Forums Problems and solutions in GDL Parameter connections GDL label for object info
This topic contains 1 reply, has 2 voices, and was last updated by  Gergely Fehér 4 years, 1 month ago.
  • #2441
    Szabadi Gergely
    Hi!
    I would like to create my own label what is calling parameters of my objects defined in the object script. I haven’t found any clue how to get started with it. Any suggestion?
    Thx!
    G. Szabadi
  • #2442
    Let’s clarify two things: in scripts you can define variables only. Parameters can only be created on the parameter list view of the GDL editor, and the available parameter list of any object is fixed, cannot be changed in scripts (except of the newparameter command in backward migration).
    Variables can not be reached or read by labels or listing or addons. If you need to “export” anything from your object, you need to add a parameter for it, and set it’s value in the paramscript. From labels you can reach parameters with a request (ASSOCLP_PARVALUE).
