The name is not in quotation marks. So it is a variable. Davids trick will not work in this case. You have to look in master script, parameter list or parameter script, which values the variable/parameter may be.
On the other side you would not need to replace a macro, if you could add your new one and add its name to the available list of values of [typ_ouv].
GDL developer | www.opengdl.org | Hamburg, Germany
