GDL switch to turn off SEO?
Home Forums Problems and solutions in GDL 3D modelling GDL switch to turn off SEO?
This topic contains 2 replies, has 2 voices, and was last updated by  Robert Nichols 4 years, 8 months ago.
  • #1772
    Robert Nichols
    I’ve developed a GDL part that creates an 2-way array of thin volumes with spacing such that they represent the joints on a panelized exterior building skin. Using SEO, I subtract the GLD object from the exterior walls and I get good joints that I can control somewhat globally.
    But I just discovered that the SEO subtraction also affects doors and windows within the exterior wall. The doors and windows are custom objects. Is there a way to exclude my doors from SEO operations acting on their containing wall using GDL or any other means?
  • #1773
    Possible workarounds:
    • create and place your object as a wall accessory, then you can “leave out” the doors and windows, so your object won’t override the openings.
    • place blocks to your openings, cut your object with this blocks with SEO, and then then use SEO with the cut object and the wall
  • #1775
    Robert Nichols
    Thanks, Gergely. I had assumed that would be my path, but I have to code it window by window. My fantasy was that there would be “SEO-off-for-this-object” switch that would let me solve the problem in a more global manner.
