Graphical editing by using hotspot : bind two lenght parameter together
Home Forums Problems and solutions in GDL Graphical editing Graphical editing by using hotspot : bind two lenght parameter together
This topic contains 3 replies, has 2 voices, and was last updated by  Barry Kelly 8 months ago.
  • #4758
    Jolan Ramel
    Hello, I am trying to write a string in my main object script that allows binding two parameter together.
    Example : *Parameter1 + 1 = Parameter2* (both parameters are determined for base values) It didn’t work but this is the idea
    Values (example):
    Parameter1 = 100
    Parameter2 = 101
    This is the string I wrote in my script for graphical editing by using hotspot:
    HOTSPOT2 0, 0, UNID, Parameter2, 1+256
    HOTSPOT2 -1, 0, UNID, Parameter2, 3
    HOTSPOT2 Parameter2, 0, UNID, Parameter2, 2
    If i drag the hotspot to make Parameter2 set at 51 the object follows and it works, but the parameter1 stays at 100
    I would like those two parameter to be bound, and if the Parameter2 = 51 then the parameter1 would be 50
    I summarize :
    If I enter a value for parameter1, the parameter2 will follow
    If I enter a value for parameter2, the parameter1 will follow
    If you know a way to bind those two parameters, it would be so nice 🙂
  • #4759
    What about …
    if GLOB_MODPAR_NAME ="Parameter1" then
    Parameter2 = Parameter1 + 1
    PARAMETERS Parameter2 = Parameter2
    if GLOB_MODPAR_NAME ="Parameter2" then
    Parameter1 = Parameter2 - 1
    PARAMETERS Parameter1 = Parameter1
  • #4760
    Jolan Ramel
    thank you so much, this worked perfectly ! I’m so glad I found help from you 🙂
  • #4761
    I am so glad to have helped you.
    Thank you for thanking me.
