Graphical editing in labels
Home Forums Problems and solutions in GDL Graphical editing Graphical editing in labels
This topic contains 6 replies, has 4 voices, and was last updated by  Geoff Briggs 3 years, 9 months ago.
  • #1770
    Graphical editing in labels seems buggy and not fully supported. I was trying to use a graphical switch (options are bound to a distances values list, so when you move the switch it changes the option) in a label. In the non-mirrored case, the switch worked but the behavior was unusual. The movable hotspot wanted to change to a plain hotspot before it would work. When the label was mirrored, the editing did not work at all. In beta I would report this as a bug, so I wanted to bring it to your attention. Also, I’d like to know the official position on graphical editing in labels. Example attached.
  • #1774
    Olga Gregus
    Dear James,
    Could you explain the details what the problem is with the mirrored one ?
    A picture about the requested working could be enough to understand.
    Olga Gregus
  • #1777
    A value list with output options is hooked to a length parameter, also with two values. You can edit the length with hotspots, so you can graphically switch between the output choices.
    Here’s a simplified drawing symbol object which shows how it should work. Graphical editing works mirrored and unmirrored. (Though I am getting a strange error in the parameter script, it says value list values are duplicated ‘0’, but they aren’t. Also the parameter script doesn’t fail. See comments.)
    Also, here is a label version of the same thing, all I did was change the subtype. The graphical editing works when unmirrored, but fails when mirrored.
    Thanks for your help. In the label it is ‘nice to have’, but if it doesn’t work I won’t pursue it.
  • #1800
    Olga Gregus
    Yes, you’re right. A mirrored label coord system is not working the same way as a simple drawing symbol or object one. But only without pointer, It looks well when the pointer is displayed.
    I’ve found this problem issue in our bug database. I hope this will be solved as soon as possible.
    Thank you for your comment.
    Olga Gregus
  • #2002
    Can you tell me if that issue, according to the database, also affects markers? For example, in a section marker, the hotspots fail at one end but not the other.
  • #2004
    James, if there is a problem with mirrored section markers, then it is a different issue. Can you describe it a bit more or send us a testfile in mail (gdlcenter@graphisoft.com)
    • #2026
      Geoff Briggs
      Hi Gergely,
      James has been helping me add floating text to a section marker. It works well but fails in one circumstance. I will start a new topic in this category so this topic can remain devoted to labels. Thanks.
      Geoff Briggs
      DeForest Architects
      Seattle, USA
