Graphical Hotspots & Complex Profiles
Home Forums Problems and solutions in GDL Graphical editing Graphical Hotspots & Complex Profiles
This topic contains 3 replies, has 2 voices, and was last updated by  shaun coomber 3 years ago.
  • #3295
    shaun coomber
    Hi
    I am working on an object at the moment, which uses complex profiles. It creates arrays of profiles and each of these can be offset. This part all works OK.
    It gets complicated because at each point, you might have 1, 2, 3… profiles aligned next to each other. This again works fine, but the problem I’m having is I would like to use hotspots to control the number of profiles at each location. However, because I can’t use the profile’s width in the parameter script I don’t know how to achieve this.
    I’d normally do something like:
    VALUES “totalWidthOfProfiles” beamWidth, 2*beamWidth, 3*beamWidth
    PARAMETERS numberOfProfiles[i] = totalWidthOfProfiles[i] / beamWidth
    Any thoughts?
  • #3297
    You can not get the profile geometry in paramscript, it is impossible in GDL.
    The user can change the geometry of a profile without touching the object and running it’s paramscript, so if you could store any information from the profile, this change would make your placed objects’ parameters invalid.
  • #3298
    shaun coomber
    Hi
    I understand that, but I am trying to figure out a way to control the number of beams using hotspots (without the profile width if that’s possible)…
  • #3307
    shaun coomber
    Hi
    I figured out a way to position hotspots correctly based on the profile dimensions using MUL.
    That brings me on to my next question…
    Although the MUL command affects the hotspots positions, it doesn’t seem to affect the length of the graphical input. See the attached test object.
    Does anyone have any suggestions for this?
    Thanks
    Shaun
