Home › Forums › Problems and solutions in GDL › Graphical editing › Graphical Hotspots in Macro
- This topic has 8 replies, 2 voices, and was last updated 5 years ago by
Szabadi Gergely.
May 3, 2017 at 16:35 #3219
Szabadi Gergely
ParticipantHi!
I have the next issue. I would like to call an object (obj0) as a macro in another object (obj1). Obj0 has graphical hotspots which edit lengths and the origo of the texture (origo-x, origo-y). If I call the object as a macro I get a note “origo-x cannot use as parameter”. I don’t understand at all. Without graphical hotspots of origo-x origo-y can be called as a normal parameter, but with hotspots it crashes in spite of the obj1 object has no error note.
hope it is understandable
Cheers!
G. Szabadi
May 3, 2017 at 17:08 #3220
KeymasterIt’s a bit strange. Can you attach a test object pair, and tell me which main version/build you are using?
May 4, 2017 at 09:08 #3222
Szabadi Gergely
ParticipantI attached the objects, I was working on. OBJ2 only call OBJ1 object. No error massage in OBJ1. Error massage in OBJ2.
I am using AC20 5025 HUN.G. Szabadi
May 4, 2017 at 09:30 #3223
Szabadi Gergely
ParticipantOBJ1
G. Szabadi
May 4, 2017 at 09:32 #3224
Szabadi Gergely
Participant -
May 4, 2017 at 13:44 #3226
KeymasterNow it is clear: the caller object must have all the parameters you want to edit.
May 4, 2017 at 14:39 #3227
Szabadi Gergely
ParticipantThank you Gergely for your quick respond!
It is strage. When I call a macro I can replace the macro parameter to a new one, but the hotspots cannot replace these parameters? I want to use this OBJ1 multiple times in OBJ2 so I can edit all the separate OBJ1 parameters with their own separate Graphical Hotspots in 3D. It is working without graphical hotspot.
Any idea?
THX
G. Szabadi
May 4, 2017 at 14:42 #3228
KeymasterYou’ll need a lot of parameters, or arrays 🙂
May 4, 2017 at 15:17 #3229
Szabadi Gergely
ParticipantI just update these objects I attached. This version OBJ1 only has one lenght parameter ‘A’ which I would like to use to scale in 3D. OBJ1 working fine. OBJ2 calls two OBJ1 and replace ‘A’ parameter with new ones. In 3D I see the purple graphical hotspot, I can scale but has no effect on the replaced ‘A’ parameters….
Do I haves to setup ‘A’ as an array type parameter instead of lenght type parameter?
G. Szabadi
- The forum ‘Graphical editing’ is closed to new topics and replies.
