GS Doors autotext
This topic contains 1 reply, has 2 voices, and was last updated by  Péter Baksa 1 month, 2 weeks ago.
  • #18807
    Bruce Walker
    I’m creating a custom door for a project, and I want to use the Autotext / General parameters for scheduling.
    I’ve figured out that #Height and #Width under the General parameters will read the B & A parameters of the door.
    What I can’t figure out is what parameters are scheduled when you use “Nominal W/D Opening Height on the Reveal Side” and “Nominal W/D Opening Width on the Reveal Side”. I’ve tried ac_unit_height and ac_unit_width, but that isn’t it.
    What parameters get read here?
  • #18808
    This is a legacy option: https://helpcenter.graphisoft.com/user-guide/65418/ says it works only with ARCHICAD 10 library.
    It calculates with B (height), wall opening top oversize compatibility option, the subfloor thickness set for the marker, and the reveal sizes set with the built-in reveal UI page: http://gdl.graphisoft.com/tips-and-tricks/reveal-options-automatic-or-scripted
