Hide Script
This topic contains 4 replies, has 2 voices, and was last updated by  Lingwisyer GC 8 months, 2 weeks ago.
  • #18200
    Hi all,
    According to the user documentation, scripts can be hidden by adding 64 to the section flag.
    <Script_3D SectVersion="20" SectionFlags="0" SubIdent="0">
    to
    <Script_3D SectVersion="20" SectionFlags="64" SubIdent="0">
    Would this be the the required change? My issue is that when I do this, I get an error when I attempt to convert the XML back to GDL saying;
    XML validation failed; invalid byte ‘ȎҪȏ’ at position 1 of 1-byte sequence
    Ling
    Win7 | E5620 x 2 | 24GB | K2200
  • #18201
    Hi Ling,
    this should work. Make sure the XML file encoding is UTF-8 with BOM.
  • #18202
    It is encoded to UTF-8 but how do you tell if it is with BOM?
    Ling.
  • #18206
    Programmer’s text editors show it usually somewhere in the status bar (Notepad++, VS Code).
    To be very sure, use a hex editor, the first three bytes should be EF BB BF.
  • #18216
    Ah, rightio. I have just been using Sublime. Checking it in a hex editor, it would appear that my modification was changing the first three bytes. It works now.
    Thanks,
    Ling.
