Hotspots in section
Home Forums Problems and solutions in GDL Others Hotspots in section
Viewing 6 reply threads
    • #2426
      Szabadi Gergely
      I have the following problem with hotspot: when i create an object with 3d hotspots and 2d hotspots, in the general floorplan the hotspots can be scaled and if I move the object, the scale follows it, but when I am in section view, I can scale the 3d hotspots, but when the object is moved, the scale does’t follow it. What do i do wrong?
      example:
      !3D script
      block 1, 1, 1
      for i=1 to 2
      hotspot 0, 0, i-1
      hotspot 0, 1, i-1
      hotspot 1, 0, i-1
      hotspot 1, 1, i-1
      next i
      !2D script
      rect2 0, 0, 1, 1
      hotspot2 0, 0
      hotspot2 0, 1
      hotspot2 1, 0
      hotspot2 1, 1
      G. Szabadi
    • #2427
      You should create editable hotspots for your object. Check it in the reference guide: http://gdl.graphisoft.com/gdl-basics/hotspots-graphical-editing/
    • #2429
      Szabadi Gergely
      Thank you!
      G. Szabadi
    • #2430
      Szabadi Gergely
      Thanks again! When I add flags for the hotspot, in section view the scaling follows the object, BUT If I have an object, where I use macro object more then one, I have problem with the unique flags because they have to be unique, but it is defined the same way.
      Any solution?
      Thx
      G. Szabadi
    • #2431
      Szabadi Gergely
      by flags I ment unID
      G. Szabadi
    • #2433
      You should add an integer parameter to your macro, for example “hotspotIdStart” and give a proper value (greater then the amount of hotspots placed in the macro) to it when you call the macro.
    • #2436
      Szabadi Gergely
      Thank you, Gergely!
      G. Szabadi
