Home › Forums › Problems and solutions in GDL › Doors and windows › How i can set WIDO_SILL_HEIGHT ?
- This topic has 6 replies, 2 voices, and was last updated 5 years, 11 months ago by
Barry Kelly.
September 20, 2016 at 13:15 #2732
Stefano De Maria
ParticipantHow i can set WIDO_SILL_HEIGHT ?
September 21, 2016 at 04:19 #2735
ParticipantYou set it where you show your image – in the settings dialogue or info box.
WIDO_SILL_HEIGHT will read this value for use in your script – not set the value.Barry.
September 21, 2016 at 08:37 #2736
Stefano De Maria
ParticipantI’m reading door script where the door have to fix sill height:
door typ A -> sill height 5 cm
door typ B -> sill height 10 cm
….if sd_typ = “Panzerdeckel” then
if sd_typ_PD = “PD 60×80 cm” then parameters sd_BiL = 0.600, sd_HiL = 0.800, sd_Bru = 0.000
sd_BRU => WIDO_SILL_HEIGHT -
September 21, 2016 at 08:37 #2737
Stefano De Maria
ParticipantSORRY… i’m writing … 😉
September 21, 2016 at 10:08 #2738
ParticipantI am a little confused as to what you are trying to do.
WIDO_SILL_HEIGHT is a value calculated from the height of the door or window from the base of the wall it is placed in.
It is not a value you can set in the object script as it is not a parameter like height and width (A & B).
While you are scripting it may always return a value of zero as you object as yet does not belong to a wall.
It is not until you place an instance of the door in a wall that it can determine a value.You can force it (for testing) in your script by saying WIDO_SILL_HEIGHT = 0.100 in the master script but you will need to remove that line when saving the object for real as otherwise it will always use that value regardless of what height you place it.
September 21, 2016 at 11:21 #2739
Stefano De Maria
ParticipantI want passed away doors with certain height from the base, for exemple:
– door A whith 5cm from the doors base to store where the wall it is placed
– door B whith 7cm from the doors base to store where the wall it is placed
– door C whith 9cm from the doors base to store where the wall it is placed
….Thanks
September 22, 2016 at 03:10 #2740
ParticipantI’m still not sure I am on the right track but you could place your door and manually set the sill height to what you want in relation to the wall base or storey level.
But if you want to automatically raise the height based on the door type then I would just add something like this to your 3D script …
if door_type = "type A" then ADDy 0.005 endif if door_type = "type B" then ADDy 0.007 endif if door_type = "type C" then ADDy 0.009 endif
Then when you place the door make sure you place it with the sill set to zero height above the wall base (or storey).
