How to display Object Attributes in 2D Viewport
Home Forums Problems and solutions in GDL Object design How to display Object Attributes in 2D Viewport
    • #4766
      Roman Gorshkov
      Hi guys,
      I am straggling to make custom 2D object. I want an object to hold 3 data field and be able to show them in viewport. Like label.
      1. How to make 2D object look like level marker?
      2. How to display its attributes in 2D viewport?
      Images attached. Thank you in advance!
    • #4777
      Bruce Walker
      Roman,
      You would create this as a Label subtype, as labels can be attached to objects.
      You create your ‘target’ using LINE2, CIRCLE2, and POLY2, as you would any 2D object.
      You create your text items using the TEXT2 command (or RICHTEXT2 – but from what you’ve shown, multiple TEXT2 lines should be enough).
      You get your data items using the REQUEST command, which can query any parameter in the associated object. E.g. to do one line item:
      r = REQUEST("ASSOCLP_PARVALUE", "building_type_parameter", name_or_index, type, flags, dim1, dim2, building_type)
      STYLE 'txtStyle'
      TEXT2 0, 0, building_type
      www.brucepwalker.com
      NVIDIA GeForce GTX 1060 8Mb
  • The forum ‘Object design’ is closed to new topics and replies.
