how to get the surface name of a complex wall
Home Forums General discussions how to get the surface name of a complex wall
This topic contains 2 replies, has 2 voices, and was last updated by  Péter Baksa 1 year, 2 months ago.
  • #4557
    David Shorter
    I have a label which uses “WALL_MAT_A” and “WALL_MAT_B” to return the index of the wall surface
    This works well in all cases except when I overwrite the surface of a complex profile.
    If I edit the surface in the profile (in the profile manager) it works OK but not when I overwrite the surface in the Wall dialogue.
    Suggestions anyone?
  • #4563
    David Shorter
    Having checked this out in more detail I conclude this is serious bug which poses a serious limitation when trying to annotate surfaces.
  • #4568
    Hi David,
    we added this as a bug to be fixed. Currently you can’t get the overridden surface from GDL.
