How to kill the graphic UI?
This topic contains 2 replies, has 2 voices, and was last updated by  Geoff Briggs 2 years ago.
  • #4214
    Geoff Briggs
    Hello,
    I’m building a customized detail marker and I want to get rid of the graphic UI and have just the basic parameter list instead. Here’s what I did: I saved a copy of the BaseMarker macro as a placeable detail marker. I then deleted the UI script entirely. I am able to place the marker and it seems to function fine, but the Marker Custom Settings panel of the settings dialog is grayed out and no parameters are available.
    What am I missing? Thanks.
    Geoff Briggs
    DeForest Architects
    Seattle, USA
  • #4217
    In the Interface script, turn off the ‘Hierarchical pages’ button at the top.
    You can probably also turn off the ‘Set as Default’ button as well.
    Also in the parameter script, find and comment the line for “HIDEPARAMETER ALL”
  • #4219
    Geoff Briggs
    Thanks Barry,
    Commenting HIDEPARAMETER ALL did the trick. I was familiar with HIDEPARAMETER but not HIDEPARAMETER ALL, and when I looked that up I learned about the new to AC22 “Enable hide/lock of specific fix named optional parameters” compatibility setting. So my initial frustration has a double silver lining.
    Thanks again, cheers.
    Geoff Briggs
    DeForest Architects
    Seattle, USA
