how to pass a whole array to a geometry functions?
Home Forums Problems and solutions in GDL 3D modelling how to pass a whole array to a geometry functions?
This topic contains 2 replies, has 2 voices, and was last updated by  Tim Haering 1 year, 6 months ago.
  • #4354
    Tim Haering
    Hey everyone,
    is it possible to pass all values from a one dimensional array to a geometry generating function without referencing the index of each single element?
    simple Array:
    dim sides[]
    for i=1 to 3
    verts[i] = i
    next i
    This is possible:
    block verts[1], verts[2], verts[3]
    But i want to pass the whole array at once e.g. something like this (not possible):
    block verts
    This would be extremly helpful for more complicated geometry functions like the tube function. Example:
    TUBE 4, 7, 16+32,
    	0,	0,	0,
    	-0.5,	0,	0,
    	-0.5,	-0.5,	0,
    	0,	-0.5,	0,
    	0 +0.2,	0,	0,	0,
    	0,	0,	0,	0,
    	0,	2,	0,	0,
    	1,	2,	0,	0,
    	1,	0,	0,	0,
    	0,	0,	0,	0,
    	0,	0+0.2,	0,	0
    For these i would like to just pass an array with the right values (for example different profiles) that can vary in length. Does someone know how this can be achieved? Thanks in advance!
  • #4355
    Hello,
    here is the technique that you need: How to use parameter buffer for polygons?
  • #4356
    Tim Haering
    Ok i guess it was a pretty basic question that should have a description in the docs since it is very useful. In the end i found a solution using the put and get() methods. I dump the values to the buffer using put and then the tube command looks something like this using the get() method. Like this the user can basically extrude any shape with any amount of vertices he likes just by changinge the shape in the UI.
    tube num_verts, 7, 16+32,
    	get(num_verts*3),
    	0 +0.2,		0,		0,	0,
    	0,		0,		0,	0,
    	0,		2,		0,	0,
    	1,		2,		0,	0,
    	1,		0,		0,	0,
    	0,		0,		0,	0,
    	0,		0 + 0.2,	0,	0
    Edit: Thanks Peter for pointing me to the documentation on this!
