I need a coordinate object that are "schedule able"
Home Forums Problems and solutions in GDL Lists and schedules I need a coordinate object that are "schedule able"
This topic contains 7 replies, has 5 voices, and was last updated by  Gergely Fehér 1 year, 10 months ago.
  • #1458
    Odd Goderstad
    How do I make an coordinate object, and schedule, that can list the insertion point of the coordinate objects? we place coordinate objects all around the building, and we need to list their positions.
  • #1460
    Hi Odd,
    If it is enough to schedule the objects relative position to the project origin, then you can make a simple object to solve the problem. Simply add 3 parameters, for example xPos, yPos, zPos, then add the following 3 lines to the parameter script:
    parameters xPos = SYMB_POS_X
    parameters yPos = SYMB_POS_Y
    parameters zPos = SYMB_POS_Z
    You can make a simple 2d representation for this object, place it, and then you can list these 3 parameters if you make your own schedule for that.
    If you need world coordinates, then there is no proper solution for that in GDL, please check GDL-Related Changes in ARCHICAD 19.
  • #1470
    Odd Goderstad
    Thank you! Could this be made to work from objects placed on a worksheet also?
  • #1499
    I think objects placed on a worksheet can’t be scheduled. You should place them on the floor plan.
  • #1530
    antoine JULLIEN
    why you didn’t use zone Tool for list your object ?
    Tonio
  • #1594
    David Shorter44
    You can use the Coordinate Dimension 18 from the old version 18 Library. This allows the coordinates to be scheduled. The 19 Object of the same name does not work
    Hope this helps
    ArchiCAD 4.1-22
    MacBook RetinaDisplay
    16Gb RAM 500Gb SSD
    BIMXdocs
  • #4308
    Thomas Lodge
    Is there a way to schedule a coordinate object that uses GLOB_WORLD_ORIGO_OFFSET?
    • #4309
      No, you can not store the GLOB_WORLD_ORIGO_OFFSET in library part parameter, so it can not be scheduled as libpart data.
The forum ‘Lists and schedules’ is closed to new topics and replies.
