IFC Library part mapping and property use
Home Forums Problems and solutions in GDL Informations from the environment IFC Library part mapping and property use
This topic contains 1 reply, has 2 voices, and was last updated by  Gergely Fehér 4 years, 6 months ago.
  • #1935
    Kristian Bursell
    I am pleased with the “Library Part Independent” function for mapping as this makes the whole process viable. However, I was under the impression that we could actually reference IFC properties in the GDL script.
    From what I have found it seems there are only a limited number of IFC values that can be referenced in the GDL script; as per the list in the GDL Reference Guide.
    Is this the limitation of IFC properties usable in the GDL script?
    Is it possible to reference other properties and control library part parameter values via the IFC properties?
    CADSWIFT
    Australia
  • #1960
    There is a set of application queries to get IFC properties and their values from library parts, search for Tags and categories on this page: http://gdl.graphisoft.com/reference-guide/application-query-options/
    You can check the usage of this queries in “Tags and categories label” in ARCHICAD19. I hope it helps.
    By the way I think IFC properties should not control objects parameters, as if the user changes anything in the IFC values, parameter script of the objects will not run – so it can cause an inconsistent result.
