Ignore WALLHOLE command
Home Forums Problems and solutions in GDL Doors and windows Ignore WALLHOLE command
    • #3234
      If I define a Window with Wallhole2 command to get some extra parts for the window,
      this wallhole commands causes that the default wallhole-cut will be inactive.
      IF I now write:
      IF fasche THEN WALLHOLE2
      Then the default wallhole-cut will be inactive as well, if fasche=0.
      The default wallhole-cut is smart and I want to use it in the case fasche = 0
      and I do not want to write an extra wallhole command for that case.
      How do I do this?
      MAC OSx 10.12
    • #3235
      Joachim,
      As I know, if you use any wallhole2 command in your openings’ script, it will turn off the automatic cut by ARCHICAD. In this situation you’ll need to take care of the simple cutting too.
  • The forum ‘Doors and windows’ is closed to new topics and replies.
