I created a scripted image fill and a material which uses this image fill. I created an object which uses this material, where I defined the origo of the material.
The problem is, that in 3D the surface is using the defined origo, but in Section/Elevation the image fill uses the global origo.
Anyone has idea how to fix it? Thx!
master_gdl_fill
define image_fill "f_test" "test_pict",
1, 1, 1, 1, 1, 1, 1, 1,
1, 1, 0, 0
master_gdl_material
define texture "m_test" "test_pict", 1, 1, 0, 0
define material "m_test" 20,
1, 1, 1,
0.58, 0.85, 0.2, 0,
50,
0,
0.878401, 0.513481, 0.412253,
0, 0, 0,
0,
ind(fill, "f_test"), 0,
ind(texture, "m_test")
object
material m_test
BASE
BLOCK 1, 1, 1
vert 0, 0, 0
vert 1, 0, 0
vert 0, 1, 0
vert 0, 0, 1
coor 2 + 256, -1, -2, -3, -4
