Home › Forums › Problems and solutions in GDL › Informations from the environment › Is there a way to query all Library Part names in the loaded Libraries?
- This topic has 9 replies, 3 voices, and was last updated 5 years ago by
Tony Krepler.
February 16, 2016 at 22:55 #2256
Tony Krepler
ParticipantI might be missing something, but I cannot seem to find such query, although I thought it was possible.
Thanks,
Tony Krepler
fjmt -
February 17, 2016 at 00:01 #2257
KeymasterThere is an application query for image files and ies files. Listing the whole library seems to be a bit useless, as normally there are thousands of libparts loaded. Why do you need that?
February 17, 2016 at 00:10 #2259
Tony Krepler
ParticipantThanks Gergely. I know about the image query, thanks.
I am calling Graphisoft chairs from our Library, and with the current version of our Library there is either the ArchiCAD Library 18 or the 19 loaded with it. Thought I can make it smart – not a biggie though, and our Library is under update anyway.
Thought I’s still ask. Thanks anyway.
(How about the Project Info queries – another post from me)Cheers,
Tony
February 17, 2016 at 09:09 #2263
KeymasterTony,
You should not call our chairs from your library – as the chairs are placeable objects. Please never use placeable elements as macros, it can cause many problems.Gergely Fehér
February 17, 2016 at 09:40 #2264
ParticipantTony,
Please never use placeable elements as macros, it can cause many problems.Such as?
I do this all the time and have not noticed any problems so far.Barry.
February 17, 2016 at 09:59 #2265
KeymasterThere will be failures in case of library updates or migrating to new versions – when parametrization of a libpart can change. Pla saving can be wrong too – you won’t be able to use your pla in an upcoming version if the called library part is migrated.
If you need one of our placeable library parts as a macro, then you should open it with the editor and save as a macro (not placeable) with a new name. Then you can use it in your libraries.Gergely Fehér
GRAPHISOFT SE-
February 17, 2016 at 10:38 #2266
ParticipantWe don’t rarely use the Graphisoft libraries as we have our own custom library that suits our needs better.
I certainly would not call objects/macros in your libraries as I am aware they can change without me knowing what has changed.I am just getting into migrating objects this last week actually and have spotted the possible problem of migrating objects called by other objects.
But I am hoping that if I keep the original names then the call will still work.
I am aware that migrating an object with a new name is probably a more logical way to keep track of them but I am hoping keeping the same name solves the ‘CALL’ problem.
Obviously there will be problems if parameters have changed in the called object but that would apply if calling a place-able object or a macro. So I just have to be careful to update any called parameters in the master objects as well.
The biggest problem I am having at the moment is remembering/finding all the objects that call other objects/macros that I want to amend/migrate.Barry.
February 17, 2016 at 12:18 #2267
KeymasterKeeping the name does not resolve the problem with migration. Called macros are stored with their ids, so they won’t work with changed elements until you resave them. I suggest to always use the source format of the libraries where you can easily search for callers of a macro.
February 17, 2016 at 22:45 #2268
Tony Krepler
ParticipantThanks Gergely very true, should not have done that. One of the “quick and dirty solutions, that worked beautifully. Should never use Graphisoft parts 😉 If it makes things any better, I always felt bad about it. 😉
The fact is, that if you take the chair, you need to re-save all it’s macros as well, and I was putting it off.On the other hand, I was always wondering how can ArchiCAD remember the ID of the macro, as all you can see is the name in the script.
I know it might be a different topic, but how do you resolve a situation, where you have duplicate macros, without re-saving them and going through every script that is calling them?Thanks,
Tony Krepler
fjmt -
February 17, 2016 at 22:53 #2269
Tony Krepler
ParticipantAnd , one more thing. When you use the Graphisoft chair – as long as it works(!), you get the new features for free. Whereas if you re-save it (and its macros) to be “your own”, you have to do it with every new version (if you want to stay up to date) and you might need to fiddle with migration scripts etc.
You’re right Barry, never use any Graphisoft stuff. 😉Cheers,
Tony
