I’ve got this label set for associative stuff thansk to excellent help here on the forum. However I want to place the same label without anything to attach it to (non assoc.). I solved it for now by creating an object instead but would prefer the possibility to use the label tool for both assoc. and non-assoc. Is it tricky or an easy fix?
A label can not have a GLOB_ID. So you have to add a parameter to get the text to label (or is it every time “x”).
In GDL you can request, if the label is associated. If it is not, you use the parameter.
