Linked objects via a text file.
Home Forums Problems and solutions in GDL GDL add-ons Linked objects via a text file.
    • #2472
      Daniel Virtic
      Hello everyone how are you?
      I know we can have a link between 2 objects via a text file. It’s working great on an individual project. If I load that project on the Server, doesn’t work.
      We used to request the file name and path, and to add a text file on the same path.
      It seems that doesn’t work on a Bim Server[I am not very familiar with the Bim Server and where the projects are stored].
      Should I use other way to make this link to work on a Bim Server?
      Any advices will be greatly appreciated!
      Thank you
      AC20 USA
      •Workstation HP Z800 2 x Intel Xeon Quad Core E5620/E5630, 36 GB ram DDR3 - NVIDIA QUADRO 4000 2 GB memory, Windows 10 pro
    • #2504
      Hi Daniel,
      I’d like to know more about the workflow between those library parts: why do you need text files, and how do you use them. If the files can not be published here, then you can send me some samples in mail (to gdlcenter@graphisoft.com).
  • The forum ‘GDL add-ons’ is closed to new topics and replies.
